I've been able to get svcd's to play on my Panasonic RV32 DVD Player by using the VCD header trick. I've been putting music videos on cd. However some of the videos come out with a green line on top as well as being chippy/scrambled on the top and bottom. The middle is usually fine and the audio is perfect. I noticed while burning these vids with VCDEsay that the vids that do this are PAL and the others are NTSC. DOes anyone know if this DVD player is able to play PAL? Is there a way to play these videos clearly like the NTSC ones? Thanks.
Well are your souce videos PAL and then you encode them to NTSC, or you trying to play a PAL encoded VCD on a NTSC dvd player. Or did you mix PAL and NTSC MPEGS on a single VCD disc?
What's the framerate and resolution of your MPEG files you're trying to burn. -
Well I didn't know that some were PAL and some were NTSC unitl I noticed in VCDEasy. So ya I guess i mixxed PAL and NTSC mpeg's on a vcd. Is it just my DVD player that cant play PAL then? Is there a way to make it play them?
Panasonic TM900 NTSC to PAL conversion...
By vkshatriya in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 3rd Oct 2011, 05:24 -
PAL video on NTSC HD TV Best motion Playback
By Deter in forum RestorationReplies: 7Last Post: 25th Aug 2011, 06:34 -
NTSC -> PAL on NTSC Playback VCR
By Cyberrock in forum Capturing and VCRReplies: 21Last Post: 28th Sep 2010, 04:52 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47 -
Vertical Stretch on PAL playback on Panasonic DVD-S35 Player
By dennis albright in forum Video ConversionReplies: 5Last Post: 31st May 2007, 08:36
