  1. So why dont these functions exists? It gives me the error about there being no functions, but its listed as being apart of 2.5. I can use other audio functions, just not those two, and of course one of em is the one I really need.
    So as I see it, I either installed it wrong(but everything else I do w/ AVISynth works like a charm) or they removed it or I need to DL something else.
    End result, I want to use a low pass audio filter in avisynth.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  2. I noticed this too, but if you read the Avisynth manual at avisynth.org,( it states that the LowPassAudio and HighPassAudio functions were removed from the 2.5 version. I have ended up saving the wav file out of my video, loading it into Audacity and using it's lowpass filter feature, then replace the old audio with vdub. Hopefully this will get put back into future versions.
    Here is the link:
    http://www.avisynth.org/index.php?page=FilterAudio
