how do you burn a dvd from 2 divx files joined together, converted to pal, audio time warped to match and get the audio and video perfectly in sync.
i've been trying to do this for weeks without success
cheers
d-j
What have you tried ?
If you've got the DivX codecs installed correctly, just load the AVI file into TMPGenc, convert it to the relevant MPEG2 format and import it into your authoring application if that won't import them on it's own.
Should be fairly straightforward. -
i've tried everything in the guides section with no luck, most refer to vcd.
i agree it should be easy to do, i can convert whole movies with no probs, i just wondered if any of you guys with dvd burners had the same problem. -
you need:
tmpgenc & dvdlab & nero
run the divx through tmpgenc with the dvd template, keep the size under 4,5 MB else it won't fit.
run the file you get through dvd lab to author your dvd. It isn't an easy program to use but i bet you can find a guide some where.
burn the video_ts with nero as a video-dvd.
thats al there is to it.
