im using ritek 4x dvd-r with the dru-500a. they wont burn at 4x, only 2x and takes approx 30min. im using nero and firmware 2.0f. am i doin something wrong or is it a compatibility issue. if so, can anyone suggest any decent media which does burn at 4x whether it is + or -
Results 1 to 9 of 9
If I'm correct the dru-500A can't write 4x without the upgrade for this drive.
TDK and Verbatim +R 4X media burns very reliably at 4X. These discs are made by Ricoh. Supposedly the Memorex 4X media is also Ricoh and should work very well. These seem to be about the best 4X media for the Sony that people have found so far. I also have 2.0f firmware and have no trouble burning these at 4X. I have a 4X media sampler on order from Meritline so I can try some other brands (especially -R types). I have not seen any 4X -R media in any of the retail stores I frequent (Best Buy, CompUSA, Circuit City) yet.
Firmware 2f burns at 4x, no problem. Maybe it's a bad disk.
Regards,
Rob -
Word! Just get media that is more compatible. 8)Originally Posted by rhegedus
You did not mention Staples in your list of frequented stores, but I have seen DVD-R 4X Memorex 25-pack in a local Staples store. I also have not seen any other DVD-R 4X disks anywhere else.Originally Posted by Metaluna
I just bought 2X DVD-R (branded TDK) from BestBuy. I saw 4X for TDK, but they were all out, also saw Memorex 4X DVD-R, plenty of those, but I am still not willing to buy Memorex cause of bad experience. The TDK DVD-R are great, they load up faster than my previous media and they also play on PS2 console.
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 12:52 -
AVCHD footage with sony HDR1 SR1E, vegas 7 wont burn DVD for me
By jonyfoz in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2007, 09:11 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 11:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
