I am modifying the bit rates to eventually burn it as an Xvcd. I was not able to do this with one of my files, it just says "filexxx.avi cannot open or unsupported".
I am following the Xvcd guide to modify settings, has anyone does this? Please post if you know how to go about this.
I have read the relevant guides availabe on the site but was not able to find the answer.
You did not find this relevant?If you get an error message when opening like file unsupported or can not open or is not supported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 or to the top of plugin-list and try open the video.
Hello. -
Thanks. I also found Arrowhead's guide, which also proved useful.Originally Posted by funkguy4
Don't know if you are the author for this guide, but if you are, wanted to bring to your attention that the last screenshot image did not load for me. Please check if possible.
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 05:47 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
What is the best freeware to convert to an XviD file.
By amadeira in forum DVD RippingReplies: 2Last Post: 22nd Sep 2007, 00:28 -
Convert 1080i .mpg to hr.hdtv (960x540 xvid)
By MrFingers in forum DVB / IPTVReplies: 4Last Post: 6th Aug 2007, 10:00
