I captured with virtualdub to 352x480 avi using huffyuv and got acceptable results, my intention is to make it a DVD. I edited with Vegas and authored with DVD Architect and found that aparently the interlacing is wrong, the image looks fuzzy when a fast pan occurs.
This is my second try, on my first try I simply converted the avi to mpeg2 with tmpgenc, and got good results, no interlacing problems. And I found that tmpgenc "found" which line goes first, if top line or bottom line. I checked in Vegas and Vegas put progressive as default on the video properties tab.
How can I make Vegas to find which line goes first, top or bottom? Tmpgenc's wizard does that job fast and easy. But I don't want to load tmpgenc before loading the video in Vegas just to find out the interlace field order.
George
Results 1 to 1 of 1
AVI Field Order
By Ash McKenzie in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2012, 01:52 -
ffmpeg/libx264 does not observe interlace field order!
By timmus in forum RestorationReplies: 13Last Post: 16th Dec 2010, 14:17 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
How to detect the Field Order of your Avis
By SatStorm in forum Video ConversionReplies: 27Last Post: 14th Nov 2007, 08:44 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
