Hi,
Can anyone help me with a major! problem i'm having.
After rendering m2p files with canopus mpeg soft encoder and checking that they have worked, I later return to find that they have been reduced to 0kb and can not be played. This has also happened with some AVI reference files, the temp files are reduced to 0kb. This problem is killing me.
I'm running win2k and all my drives are NTFS.
good idea I'll give that a go, hopfully i can get to them before it happens,
one i just rendered over night reduced to 0kb before i got to it today. ggrrrrrr. -
Maybe you'll having trouble setting the file mode during a program running on this file.Use filemon for checking, which program hogs your files. Should be found here:
http://www.sysinternals.com -
yep even after i select read only, i have even tried searching for viruses and completed a complete reinstall of win2k, .... i'll try that program, then i might try windows XP
Deleting files and directories
By Jomapil in forum ComputerReplies: 11Last Post: 20th Mar 2012, 05:41 -
Deleting cookies?
By neworldman in forum ComputerReplies: 3Last Post: 21st Jun 2011, 12:52 -
Deleting subtitles from videos
By angeloslev in forum Video ConversionReplies: 1Last Post: 23rd Feb 2011, 21:33 -
GOTSent deleting files upon completion
By draco_nite in forum Video ConversionReplies: 1Last Post: 2nd Nov 2010, 10:16 -
Convert to M2P
By BuzzStPoint in forum Video ConversionReplies: 4Last Post: 25th Dec 2009, 13:24
