i have downloaded a working VIDEO_TS from the internet, whats the best program and way to burn it?
I usually use Nero 5.5.10.42, then do a UDF/ISO (bottom on the list), drag the VIDEO_TS folder and create an AUDIO_TS folder too.
Is the correct format UDF/ISO or should i be using something else.
Or can i create an ISO from the VIDEO_TS and then just burn an image via Nero, whats the best program then to use.
Best program i've used to burn dvd's is Stomp RecordNow Max. ImgTools (freeware) also works for me.
Burning a VIDEO_TS folder to disc makes it a playable DVD right ?
By Bansaw in forum Authoring (DVD)Replies: 25Last Post: 1st Mar 2015, 15:34 -
Burning from Video_TS
By Wanderlustus in forum Authoring (DVD)Replies: 14Last Post: 10th Oct 2009, 11:15 -
Burning DVD with VIDEO_TS Folder
By bguguen in forum MacReplies: 7Last Post: 28th Jul 2009, 00:10 -
Burning VIDEO_TS folder to a DVD disc as Video not Data
By xtaint in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 08:23 -
problem with menus when burning VIDEO_TS files to DVD
By samd292 in forum MacReplies: 3Last Post: 24th Jun 2008, 08:49
