Just reinstalled ffmpegX on my Mac OS 10.2.6 system. I had ffmpegx 0.0.6 something and decided to see if a new one was out. I installed 0.0.7d along with the engines (but not the libogg and libvorbis libs -- I have those installed by fink).
Anyway. when I start encoding an MPEG4 video to MPEG1 for a video CD, ffmpeg (not ffmpegX -- I checked in top) starts using 600MB of memory and grinds my system to a halt. A couple times (I tried this multiple times) a dialog even came up warning me that my system is low on memory and may start acting weird (it did!).
ffmpegX worked fine before. I don't know what's causing this memory overload. Any ideas? I can post more details if you need to know them.
Chris
cluthGuest
cluthGuest
All right: it works fine with the other movie I used awhile back. It's this particular video file that's choking up the works.
The movie I'm trying to convert is an Apple QuickTime/iMovie MPEG-4 that a friend of mine produced, and I'm using mpeg2enc to convert to VCD (per the preset).ffmpeg runs for a little while (using most of the CPU and boatloads of memory), and then yuvscaler spits out an error of some sort (if the system doesn't get a VM overload). I'll recreate the error later so I can give you the exact text of the error, but for now I may be able to get my hands on a more raw version of my friend's video.
Chris
cluthGuest
Results (happens after about 10-15 seconds of working and using gobs of memory):
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
Encoding then quits.
Here's a snapshot from top -w while it's encoding:
PID COMMAND %CPU TIME #TH #PRTS(delta) #MREGS VPRVT RPRVT(delta) RSHRD(delta) RSIZE(delta) VSIZE(delta)
1567 mpeg2enc 0.0% 0:00.01 1 9 14 1.10M 56K 488K 308K 1.60M
1566 yuvscaler 0.0% 0:00.01 1 9 14 1.06M 56K 376K 288K 1.55M
1565 ffmpeg 32.5% 0:07.20 1 9 16 641M 409M(-540K) 528K 208M( -46M) 643M
1561 sh 0.0% 0:00.03 1 9 13 952K 96K 700K 520K 1.79M
UnknownOneGuest
Hi all,
I just wanted to say, I get that too but with Version 0.6m, but only after my 4-5 encodes without quitting the program and restarting it. It works fine after I quit the program and restart it.
BP oil leak live video from well head
By redwudz in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 15:14 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16 -
firefox 3.5.1 - does it have a memory leak?
By minidv2dvd in forum ComputerReplies: 9Last Post: 12th Aug 2009, 10:31 -
FBI arrests man over leak of Guns N' Roses songs
By Conquest10 in forum Off topicReplies: 22Last Post: 28th Aug 2008, 23:17 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 07:19
