first off, major, you've done a fine job on this program!!!
i have a captured QT mov that i'm trying to get into m2v.... the QT mov plays fine with the audio / video in perfect sync.
after running it through ffmpg to create the m2v, the audio and video start at the same time but, about 4 seconds in the film, the audio jumps about 3 seconds ahead and stays that way for the duration on the mov.
looking at the times of the audio and video in the Finder, the audio file duration is 3 seconds shorter than the video file. the time difference can also be verified in Final Cut Pro.
in ffmpg, i selected the hi quality preset, de-interlace, QT decode....
ffmpg is the fastest encoder and i would prefer to use it over FCP (8 hours to encode vs. 30 hours just to render in FCP)
any guidence is greatly appreciated.
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 05:31 -
MiniDV to DivX/XviD (w/ AutoGK): audio out of synch due to dropped frames??
By alexon in forum Video ConversionReplies: 6Last Post: 17th Dec 2009, 03:54 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 22:21 -
Pioneer DV-410V, I dropped it
By rimbaud in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th Apr 2009, 08:36 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 13:57
