Hey,
I recently found out that my new dvd The LG DC595NWQ is not playing SVCD. I searched for some hacks and i found about that hack...
SVCD Hack for LG 595NWQ
1 - Power up the dvd with no disc
2 - Press Pause and then press 1,4,7,2
3 - Press up arrow 6 times, the characters 07 00
should appear on the display, and on the TV
4 - Press: Program key, 6, Program key, 5
(the characters 07 FE should now be displayed).
5 - Press Enter
6 - Press Return
7 - Power off and power on the player
I tried that hack by playing some 2 disc svcd... the first disc didn't even play it said "Disc Error", and the first disc played but you couldn't understand any of the sound or see the picture clearly it got stuck it had green square's on it, in other words didn't work good at all.
then i read in some forum that you first have to do the vcd Hack....
but my vcd are playing good... i dont know what to do....
please help!!!
o and can you somhow undo the svcd hack? or any hack?
~~~~~~~~~ Please Help
if you want to undo the hack,just re-enter the info the way you did already,but change the "FE" back to whatever it was,in this case,"00".
but i think your svcds werent donr properly to begin with.i fond that they have to be compliant svcds,and nero for me works best this way.
what you have there seems to me to be an svcd with the vcd header trick involved..
Problem with DVD Architect: m2t file is being read only half the length
By eising in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2011, 04:30 -
Problem playing DVD
By kevinlane in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2011, 08:49 -
LG DVD player USB file read problem
By Movie_Snatcher in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Nov 2009, 15:03 -
Problem: PC can not read DVD
By manhnt in forum Newbie / General discussionsReplies: 7Last Post: 11th Nov 2007, 17:05 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
