Hi all, I've got a VCD which has a .dat file that I want to convert to .mpg I've used VCDGear2.0 to convert it but the sound is WAY out of synch. I've tried remuxing with BBMPEG but it does not work. Any suggestions??
zeppsstteerr
copy the .dat to your harddisk and rename it to .mpg
I'm serious,it works -
Mike is correct, I do this all the time when I want to make another copy of a VCD, just did it last night on 9 different .dat files that are country music video's from Dishnet Sat. I had captured months ago and burned to a VCD.
Hi guys, tried that and it doesn't work. Still have the same synch problems. Thanks for the suggestion.
zeppsstteerr -
Yes, the renaming of DAT to MPG works for me too. What are you using to view the MPG's?? Try Windows Media Player - it works for me every time and with no audio sync problems.
zeppsstteerr,after you copy the .dat file to the harddsik,try playing it,is it out of sync ? If it's,try defragmenting your harddisk.
Hi, I'm running Win98 and am fully defragged. I'm using Windows Media Player but still have the audio synch problem. I'm going to try running the .dat through TMPGenc and see what happens. Thanks for all the hints.
zeppsstteerr
DAT/MPG to VOB/MKV?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2011, 06:21 -
DAT to DAT cutter?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2010, 12:13 -
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 21:29 -
DAT to MPEG 1
By MI6 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 16:01 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48
