I ve just rip my first soundtrack from a 2-DVD set of Led Zeppelin. I have try all the besweet stuff, but it just too confusing.
1. Rip your VOB to harddisk using DVDdecrypt
2. Open the ripped VOB files in Goldwave
3. In Goldwave, do File>Save As> your mp3 format
walla, you are done. Now you have a burnable mp3 file of the movie you want. If you are having problem with save as mp3, do save as wav files, then burn it to cdr.
Good luck...
What if the dvd has several audio tracks? Doesn't goldwave select the first one?
You can also rip directly to ac3 with dvddecrypter and then convert to wav with goldwave
https://www.videohelp.com/forum/viewtopic.php?p=591008#591008
easiest way to rip dvds WITH dual audio to MKV or AVI
By angryassdrummer in forum DVD RippingReplies: 13Last Post: 19th Dec 2011, 00:40 -
How to rip dvd audio to mp3 or wav files?
By babypotato in forum DVD RippingReplies: 12Last Post: 17th Jul 2011, 03:22 -
Easiest question ever - jpg+mp3=video. (for youtube)
By noiz in forum Newbie / General discussionsReplies: 6Last Post: 14th Aug 2010, 19:10 -
Best/Easiest way to make multiple segments of a mp3 file?
By raydeneg in forum AudioReplies: 4Last Post: 7th Oct 2008, 08:47 -
Easiest method to rip a DVD to a Windows Movie Maker compatible format
By computer2slow in forum DVD RippingReplies: 6Last Post: 9th Apr 2008, 19:11
