Results 1 to 10 of 10
  1. Whats the story with these. Nero's telling me its an illegal media. Now I've not had it that long but I have wiped it a couple of times. Is it knackered? Do they really last so little a time? Im using a Ricoh disc in a Ricoh drive.
    Manhattan, NY
    Are you using an old version of nero? I use +rw all the time without a problem. You may need to upgrade your nero
  3. im using ver 5.5. is that a prob? ive probably wiped the rw 20 times.
  4. I use Philips (PHILIPS.001) and Memorex (RICOHJPNW01) DVD+RWs.
    I`ve rewritten some of them at least 100 times, still work well.
    All my softwares and firmwares are up-to-date. My drive is set to write ROM booktype. Therefore I have no problem.
    The latest Nero5 is 5.5.10.42 at the moment.
    Boulder, Colorado
    I had some that were rejected by Nero as well, all it means is that particular RW was physically bad, We win some and we loose some. Welcome to modern manufacturing.
    Manhattan, NY
    I have only had one physically bad +RW. I typically stay with Khypermedia +r's and +rw's. They are really cheap and really good.
    And you say you have ver 5.5......5.5what...there are a lot of 5.5 versions
  7. Try doing a full erase instead of a quick one - I don't have any idea why this worked for me on a -RW I had "die" on me a while back, but it did - might work for you on the +RW... ?
  8. Thanks. Looks like I've just got a bad one. Its Nero 5.5.10.35 btw and I can't do a full erase either. Oh well
  9. try other programs than nero
  10. Banned
    May 2003
    Massachusetts
    I've had some +RW's that work from the box, and others that I had to do a COUPLE full wipes on before they'd work.
    If you have access to RecordNow, try that.
    - Gurm
