Hi Folks!!
In my DVD Maestro Project, the FIRST PLAY and TITLE MENU function are connected to my MAIN DVD MENU. Everything works fine - I insert the DVD and it starts automatically with the MAIN MENU. BUT....if i am pressing the STOP button - the DVD stopps - and then the PLAY button - the dvd is playing the next movie in the SOURCES list, but it should start again with the MAIN MENU!!!![]()
I cant find anything in the maestro documentation about this problem!
I hope, somebody can help me here in this forum!
thx a lot
_Trinity
I'm not sure how you want it to work (seeing you have multiple movies), but here are some clues for you from the Manual.
Inserts the disc. That's all.“First Play” (the source to use when defining what happens when the end-user first
inserts the disc).
I'm no expert, but maybe you can do what you want with playlists. There is a guide that talks about them.“Automatic” chapter-to-chapter connections — where each chapter plays seamlessly
into the next, without having to establish a connection for each chapter’s End Action.
For instance, as Chapter 1 ends, Chapter 2 begins playing seamlessly. This continues
through all of the chapters, except for the last chapter of a DVD Movie, where you
will need to establish a connection if you want something to occur when the last
chapter of the DVD Movie has finished playing.
Note: Automatic Chapter-to-Chapter connections are not displayed in the
Connections window and take place “behind the scenes” without any further
action on your part. You can override these connections simply by establishing a
new connection for any given Chapter’s End Action state. Also, if you want
seamless playback between successive Chapters, do not establish connections
between Chapter End States and new Chapter Markers — since this may
introduce a slight delay between Chapters.
Hope this helps....
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 12:42 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 02:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
Help! DVD Maestro RealTime preview. Cinemaster not working.
By IJM in forum Authoring (DVD)Replies: 10Last Post: 1st Jan 2009, 04:22
