  1. Hi,
    Is there anyway to covert an avi file that has divx encodeing into an meg that does not have it.
    geri
    <font size=-1>[ This Message was edited by: gerily on 2001-09-28 13:46:04 ]</font>
    Feb 2001
    Berlin, Germany
    I am not sure, what you mean, but you can convert Divx to MPEG.
    http://www.vcdhelp.com/convert.htm
  3. I'm trying covert an avi file with divx into meg so I did not have to install the divx encode software to a computer but the meg file still needed the divx software to play is there anything else I could do.
    geri
    Feb 2001
    Berlin, Germany
    DivX is a AVI codec. You need it to compress a AVI to a DivX, that is still an AVI. If you want to play a DivX-AVI with a software player, you must have installed the DivX codec. If you want to convert a DivX-AVI to MPEG, you must have installed the DivX codec and you have to use a MPEG encoder. You don't need a divx codec to play a MPEG.
    Note, DivX is compressed AVI. MPEG is a complete different format.
    http://www.vcdhelp.com/faq.htm#divx
    http://www.vcdhelp.com/faq.htm#mpeg
  5. thank you for all your help
  6. Just an aside - DivX is MPEG4 compression (with a *.avi extension). VCD is MPEG1 and SVCD/DVD is MPEG2.
