I'm checking out Vegas 4 and I can't find how to frameserve to tmpgenc with it. I think I read someplace that this version of Vegas do frameserving, Am I wrong?
If it can, how?
George.
Only on days ending in Y
Go here for Vegas "framesever" plugin. It works i have tested it. (on 3 - should work on 4)
http://www.debugmode.com/pluginpac/frameserver.php
From the webpage
Limitations
1) There are some issues with audio serving from Vegas 4.0b and earlier (not in Vegas 4.0c), so seeking back in audio will cause any subsequent audio reads to return empty samples. In such cases, use the "Write audio as PCM samples in AVI" option. This can also be used in other software which are unable to read the FrameServer audio. -
I;ve tried to frameserve with vegas 4.0c to tmpge,and with transitions i get audio sync problems.If i save the project as an avi and then render it in tmpge,no problems.Not sure why,but i suspect the transitions are causing the problem.
bmiller,ont.canada
Hello..been a long time-Can I upgrade from vegas 5.0 and DVD arch 2.0 to Vegas Pro 9
By arcorob in forum Newbie / General discussionsReplies: 6Last Post: 1st Feb 2010, 21:31 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 31st Aug 2009, 00:40 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 01:41 -
frameserve from Vegas to HCEncGUI?
By ecc in forum Video ConversionReplies: 13Last Post: 3rd Jan 2009, 19:45 -
Vegas Movie Studio Vs Vegas. Crippled levels?
By fredfillis in forum EditingReplies: 0Last Post: 3rd Jul 2007, 16:16
