Does anyone know if there is a program that can edit only the sound of say a mpg or avi file without having to re-encode the whole file? Is that even possible? I have found programs that can extract just the sound from a video but i am still in search of one that can import sound back in. any suggestions? -dan
You can use TMPGenc Mpeg tools. Just go to the re-mux tab, put in the video and audio files and it combines them.
Yes, more specifically, open TMPGEnc, click File>Mpeg Tools, click on the Simple Demultiplex tab. Input your mpeg file, click RUN. This will split your file into seperate audio and video files. Open your audio file in Goldwave (free demo), edit and save as wav file. Go back to TMPGEnc and on the main page, click ES (video only). Enter your wav file in the Audio input box. Click the START button and let it process for a few. Again click File>Mpeg Tools and click the Simple Multiplex tab. Enter your original video file and the sound file that you just made and click RUN. That is all.
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
Try to edit my mpeg but no sound!
By leegundo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 2nd Aug 2010, 10:56 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 05:08 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
Problem with Magix Movie Edit 14 - Sound muted between objects.
By Jo The Veteran in forum EditingReplies: 1Last Post: 3rd Jun 2009, 17:49
