  1. Is there a way to open .MOV videos using virtualdub?
  2. Member DJRumpy's Avatar
    Dallas, Texas
    You only need the proper codec. If you have quicktime installed, it should take care of the problem. If your not sure, you can also use GSpot (find it in the TOOLS section to the left). It can tell you if you have the necessary codec installed.
    Impossible to see the future is. The Dark Side clouds everything...
    Virtualdub doesn't support mov. EVen if you have quicktime installed. But you can use this method
    https://www.videohelp.com/forum/viewtopic.php?t=170058
  4. Member DJRumpy's Avatar
    Dallas, Texas
    Your kidding? I wonder if there's a MOD version for it, or at the least, directplay support.
