  1. i just finsished converting my avi to svcd the final output file is 2.1 gigs how do i burn it as svcd do i split the file every 700megs
  2. (S)VCD mode 2 burning allows you to fit upto 800 MB on a 80 min/700 MB CD-R. The 700 MB is for mode 1 data/audio burning.....(S)VCDs are burned in mode 2, yielding the extra 100 MB.
    however, with overhead...you might be able to fit max of 795 MB/CD-R. so, you need to split the file according to that size.
    spliting files:
    https://www.videohelp.com/bbmpegedit.htm
    https://www.videohelp.com/tmpgencedit.htm
    https://www.videohelp.com/forum/userguides/119181.php
    burn:
    https://www.videohelp.com/nerosvcd.htm
    https://www.videohelp.com/vcdeasyhowto.htm
    https://www.videohelp.com/vcdimagergui.htm
