Under the advanced tab for MPEG Settings, what is the basic difference between "Full screen", "Full screen (keep aspect ratio)" and "Full screen (keep aspect ratio 2)"
Additionally, what settings would you use for a "Full screen" video if used 16:9 settings seems to stretch the video out (ie: 580x326 Pal video)
Full Screen will stretch the image to fill the screen - destroying (at least, possibly) the aspect ratio. Typically you don't want this option as it will distort the images.
The full screen (keep aspect ratio) streches the image to the full screen without distorting the image. This can result in you seeing black bars on the bottom/top, or left/right of the picture because it won't stretch the image farther in one direction than another (it preserves the aspect ratio).
I don't know the difference between full screen (keep aspect ratio) and full screen (keep aspect ratio 2) - they seem to work the same.
To answer that question, I'd need to know the display aspect ratio of the picture going in - is it 4:3? 16:9?Additionally, what settings would you use for a "Full screen" video if used 16:9 settings seems to stretch the video out (ie: 580x326 Pal video)
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
Unable to view streaming URL in full screen theater mode Adobe 10
By badger1194 in forum Video Streaming DownloadingReplies: 1Last Post: 5th Aug 2010, 21:12 -
Question how to correct full screen mode too small
By jimdagys in forum ComputerReplies: 2Last Post: 12th Jul 2009, 20:34 -
PowerDVD 7: Black space gaps in full screen mode
By Asgrrr in forum Software PlayingReplies: 7Last Post: 18th Jan 2008, 17:46
