I have DVDSPro installed, and Quicktime pro. The qtmpegexport.component is in system/library/quicktime, but when I try to export from qt to mpeg2 I find that mpeg2 is not an export option.
Very odd. The component shows up as a folder, not a package like the rest of the qt components - could that have something to do with it?
it will show up as a folder.
Try re-installing the package and then run software update. If you are using Quicktime 6.3, you need to update the MPEG2 component by way of the software update.
Final Cut export to MPEG2?
By Alex_BGD in forum MacReplies: 11Last Post: 14th Nov 2011, 13:20 -
default settings to export quicktime in premiere
By kidkunjer in forum EditingReplies: 0Last Post: 16th Sep 2010, 02:03 -
FCP Downconvert and Export 16:9 to Quicktime
By Jeff_NJ in forum MacReplies: 1Last Post: 24th Oct 2008, 11:45 -
Export .mpg files in QuickTime Pro..no audio
By sknox in forum MacReplies: 4Last Post: 16th Dec 2007, 05:20 -
Export to FCP Quicktime Movie
By James in HD in forum MacReplies: 2Last Post: 2nd Dec 2007, 08:43
