At first I thought it was a problem with DVDit, now I see that all my apps including Ulead DVD MovieFactory 2.0 have the same problems.
The Menus and Buttons look fine, and fit perfectly when designed in my programs, but when played on any stand-alone player the Menus and Buttons are huge and skew beyond the screens view.
Any idea on why this may be happening?
THX 4 lQQking in.
TVs tend to clip off the edges and scale things up slightly. They should appear fine on your comp's DVD software. There really isn't anything you can do about this except for just making your menus smaller.
Thanks for the info, but it's not slightly larger, it's about double the size that it's intented to be.
But yes, oddly enough, it looks perfect on my comp...
Any other ideas folks?
THX -
Try DVDLab
It has a "preset" area (just use the "inside" boxes in the menu section) that you can add your buttons and menus to...plus, you cant beat a FREE 30 day trial...
My HD YouTube vids not coming out wide-screen
By cameraz in forum Newbie / General discussionsReplies: 4Last Post: 21st Nov 2009, 17:39 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
Any DVD player that will play divx files larger then 2GB?
By David9799 in forum DVD & Blu-ray PlayersReplies: 27Last Post: 9th Nov 2007, 11:53 -
Auto-fit seemingly creating larger DVD's
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 16th Oct 2007, 17:08 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37
