i've installed a file to read quick time files on TMPEGEnc, and it works, sort of.
it does play and encode quick time files, but the quick time files that i want to encode. it just shows a white screen. i've installed ON2 codec to help but nothing.
the files that i want are encoded with ON2 codec, so is that the problem.
do i have to change them to .avi in order for TMPEGEnc to notice them or can i change a setting that you show the footage.
i used rad video tools to convert them into .avi files but the result is a white screen again.
am i missing a codec?
Thanks.
Choppy Video- Hard to watch in Quick Time
By RS4425 in forum MacReplies: 5Last Post: 1st Sep 2010, 16:03 -
converting Quick Time
By butterflies in forum Video ConversionReplies: 12Last Post: 4th Dec 2009, 09:36 -
Quick time reference (.mov) also readable with WMP?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2009, 12:37 -
Quick Time Pro Help
By Soccerman77 in forum Video ConversionReplies: 1Last Post: 14th Dec 2007, 11:38 -
Quick Time Failure, HELP
By jackboyko in forum ffmpegX general discussionReplies: 1Last Post: 25th May 2007, 14:41
