hi is there any ways or tools to make streaming videos like asf/wmv seekable? i tried using asftools but that didn't work. all it did was enable the seekbar but when i try to fast foward, the movie just stalls and does go to that part. thanks
not really no
if it's in mpeg4 or divx format then you could use asftools to extract it to a avi file - then you could do whatever you want
however if it's using one of the windows media video ( WMV ) codecs then you will still be able to extract it but nothing would be able to open the file
because the WMV codecs are directshow while AVI codecs are video for windows.
Codec problem in ASF/wmv file (wvc1)
By ezzeee1 in forum EditingReplies: 7Last Post: 25th Feb 2011, 21:16 -
ASF/WMV - DVD-player compatibility
By Digiface in forum Video ConversionReplies: 3Last Post: 12th Jan 2009, 13:02 -
Anyone knows how to convert ASF / WMV to Mpeg2
By macuser1960 in forum ffmpegX general discussionReplies: 3Last Post: 9th Feb 2008, 17:38 -
Converting an ASF (WMV) file
By yadda in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 07:16 -
May I know which software can convert a wmv or asf file to better viewable
By sniper in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 13:22
