  1. Is there a way I can change the menu of an authorized dvd project?
  2. Not sure what 'authorized dvd' means? But yes, you need to re-author the DVD with a new menu. See the author guides to the left. What exactly are you trying to do?
  3. I have a dvd project in my hard drive but I don't like the menu. I would like to change it without re-athoring the whole project.
  4. Member solarfox's Avatar
    Aug 2002
    Details are required.
    Did you author this DVD project yourself out of AVI or MPG files on your hard drive? If so, using what authoring program, and why can't you (or don't you want to) just go back into that same program and change the menu?
    If it's not your own project (i.e. if it's a "ripped" image off of a commercial disc), or if it's a project for which you no longer have the original files and all you have left is the ISO image or the VIDEO_TS/AUDIO_TS directories and VOB/IFO files, then as far as I know you're pretty much SOL as far as being able to re-do the menus.
