  1. i have converted some avi files to mpegs using tmpgenc
    i try to make vcd's using winoncd6 but they burn the components in the wrong order
    can someone tell me how to batch encode in tmpgenc
    iwhen i try to load the mpegs to the list i get an error message saying unrecognized audio stream
    please help
    Thx
    Apr 2003
    my computer, where else?
    when you get to the end dialogue in tmpgenc, it says something like "start encoding now or create another project." just choose the "create another project" until you've added all the files you want to encode. then, when you've added all the file you want to encode, choose "start encoding immediately" option and the batch encoding will begin.
  3. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    if you're getting an error for an unreadable file, it's probably not a batch encode problem, rather it's TMPG can't work with the file you are trying to input into it.
    if you can "start encoding immediately", but it won't let you batch encode that file, THEN there's something wrong with your batch encode.
    are you loading mpeg's for batch encode, or are you loading avi files? if you are loading mpegs, why are you reencoding them?
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
