about 90% of the time i burn a vcd or svcd the picture seems to break up around the last few minutes of the movie or sometime around last 15 mins of a vcd. i use nero to burn and im using files that i have downloaded. the only way i can get it so that it doesnt screw up is if i re encode them with tmpgenc.
Results 1 to 9 of 9
Have you removed bad frames ?, does it break up when you play it on your home computer ?
VancityG
Originally Posted by VancityG
a) You are using Nero to encode to MPEG ... AND ...
b) You are using Nero to author the VCD ... AND ...
c) You are using Nero to burn the disk
Nero is neither a good option to encode, nor to author the VCD. I had faced the exact problems when I used Nero because it appeared so simple, all everything within a one-step package.
To encode use TMPGEnc, which is the best piece of encoding s/w available. For authoring a VCD use VCDEasy.
Burning can be left to VCDEasy or Nero. In case you wish to use Nero to burn, you should create the bin/cue file from VCDEasy and burn at low speeds. Although I have burned at 32x without problems, it is safer at 4x or lower.
Regards,*** My computer can beat me at chess, but is no match when it comes to kick-boxing. *** -
at least yours play
made vcd coasters on old computer with pinndv and older nero--no luck did not play on any of my sony stand alones that claim vcd capability
new sony p4 machine burns a nice dvd with pinn8 and nero5.5---vcd's still coasters--don't play on either comp with windows media or power dvd would be nice if i could burn vcd's that work somewhere
oh welli compute - therefore i have heartburn -
first of all the files im trying to burn r vcd and svcd files of movies that i have downloaded from irc. the only way that i am able to get the movies to work is if i reencode them with tmpgenc. i never use nero to encode movies. and i dont think it has to do with the dvd player cuz if i copy the mpg from the disc back onto my computer and watch it it still has glitches in it so i think it has something to do with the burning process. ive tried so many things only thing i can think is maybe having a slow cpu is causing a problem cuz mine is only 533mhz but i dont know if that would affect anything.
Originally Posted by pbhalerao
@pbhalerao,
personally, i've never had any problems with nero authoring (S)VCDs. it works quite well. however, nero's encoder is very much lacking.
@VancityG,
nero "authors" your .mpg files into (S)VCD when you choose the (S)VCD template in nero. you don't need to add any menus, etc.... to be considered authoring.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25
