This is from the buymusic.com site:
How did they come up with that?What’s the difference between “plus” and “minus” CD burners and CD media?
Your CD media, or blank disks, must be compatible with your CD burner. There are two types of burners and four types of media.
It doesn’t matter if your burner is internal or external, it is either a “plus” or “minus” burner. CD+ burners burn CD+ disks. CD- burners burn CD- disks. Examples: You can burn your music files onto X Brand CD+R disks using your Y Brand CD+ Burner. Or you can burn your music onto W Brand CD-R disks using your Z Brand CD- Burner.
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
New DVD ROM drive, works but PC warns on boot up
By LWC in forum ComputerReplies: 15Last Post: 24th Dec 2008, 17:19 -
Adobe warns of FAKE FLASH MALWARE
By ahhaa in forum ComputerReplies: 2Last Post: 6th Aug 2008, 13:22 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
