Hi, Can someone please help? I'm trying to back up my copy of the Office series one. It is a 2 layer DVD. When I try and rip it with DVD Dycrypter it only copies the first title and there are six on the DVD. I have selected all of the files and copied them to a directory on my hard drive. I then tried DVD shink but it bins out before it gets a third of the way though. Any help that can point me in the right direction will be greatly recieved.
John.
HI Funkguy4,
No I don't mind loosing the source menus. Please reveal the ancient chinese secret to me! -
Frameserve each VOB set from DVD2AVI to TMPGEnc. This is to make the files smaller (you will probably lose an slight bit of quality). When you have frameserved each set and they have all been reencoded and add up to less than 4.37GB, then start up your fav DVD Authoring program, but no Ulead crap because it just sucks. I recommend TMPGEnc DVD Author or DVD-Lab. However, with DVD-Lab, if you have 4:3 and 16:9 anamorphic, it won't do it on 1 disc and you'll have to use TMPGEnc DVD Author :P.
cannot create i have a multi film menu
By ballboy in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 20th Feb 2012, 17:22 -
Advice needed! Multi-stream recording from various inputs.
By Corbey in forum Capturing and VCRReplies: 4Last Post: 6th Jan 2012, 09:35 -
Help needed! Hacking LG BD390 to Multi region
By PANOS in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2011, 09:35 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 17:46 -
Help - Samsung R155 multi region unlock code needed
By pixie in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Aug 2008, 11:33
