Hi all,
I ahve lots of cartoons that are in DIVX format and i want to put them onto VCD.
I am trying 1 program at present,
1. TMPGEnc
1. With TMPGEnc i found that the re-encoding to MPEG 1 was easy but I cant figure out how to do a batch - i know that i can fit approx 5 episodes onto a standard 700mb cd but cant work out how to use the batch option. Basically i want to select 5 episodes and leave my pc to it rather than keep monitoring it.
I have also heard TMPGEnc can provide moving menus i.e. options to chose which episode you want to view with thumbnails etc - any odeas how to do this?
The only other thing i have used is nero - it re-encodes it and burns for me but the menu facility is very limited. I can only put numbers 1 through to 5 with the episode names on when i really want pictures next to the episode names - for some reason this does not work.
P.s. i have read the guides but am at a loss.
Ok, the batch processing works like this:
Load up your file, do all your settings as normal, then go to File -> Add current project to batch list.
Do this for all 5 shows. Then, you'll need to make a short clip from every video for your motion menus. You can use a tool called MPEG2Cut to accurately cut about 15 seconds of video for each motion menu button.
Then, go use an authoring tool like DVD-Lab, and voila!
Converting a DVD to AVI with all menus intact
By beatsntoons in forum Newbie / General discussionsReplies: 4Last Post: 17th Dec 2009, 14:39 -
how to suppress vocal on karaoke vcd made from video files dowloaded
By sabaideevh in forum Video ConversionReplies: 6Last Post: 3rd Aug 2009, 05:57 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Converting discs made on a set top box.
By mtdg in forum DVD RippingReplies: 3Last Post: 20th Sep 2008, 15:51 -
Tmpgenc dvd author 3 menus
By forare in forum Authoring (DVD)Replies: 1Last Post: 17th Apr 2008, 06:08
