I have a DTS audio disc which is a .wav file. Unfortunately the cd ends abruptly. Is there a way to insert a fade out at the end? I don't know any tools that can either do it on the DTS WAV file itself or demux it back to 6 wav files that I can simply edit in cooledit pro.
Just downloaded the demo but it opens it as a regular wav file, so I only hear noise. Same as when I play the dts cd in a regular cd player (doesnt support dts).
Tried looking for dts in the demo but can't find it. Also can't find DTS mentioned on the site in the program specs. So how do you do it? -
any cd player can play dts cd mucic,what you need is a audio receiver with dts decoder,and olso you can't play back a dts wav file on your computer ,only if you have a dts decoder on your audio pc card,.
and if you want same demos DTS wav files,check this site http://www.christinamultimedia.com/digitalimmersion/downloads.html -
I don't think you understand. I have a dts audio cd. it works great in my dvd player and receiver. Only it stops suddenly (in middle of sentence) so I want to create a fade out.
Originally Posted by ssi1975
Video/Audio out of sync with dts track
By taraquedo in forum DVD RippingReplies: 0Last Post: 3rd Sep 2010, 03:35 -
Resync slow dts audio track in MKV
By forsh86 in forum Video ConversionReplies: 2Last Post: 17th Aug 2010, 21:22 -
M2TS & DTS Audio Track
By GeeForce11 in forum Blu-ray RippingReplies: 25Last Post: 14th Jul 2008, 20:31 -
extract entire ac3/dts audio track from a DVD
By shiet in forum AudioReplies: 1Last Post: 24th Feb 2008, 02:26 -
Fade in Fade Out a CD Track
By mn072065 in forum AudioReplies: 2Last Post: 2nd Jun 2007, 03:39
