I thought the file that I had was already a VCD, because the FPS was 14.98. Thus, I tried to compile it in Nero, and while draging it into the new compilation, there was an error, unsupported file format.
Why does it say this? And How can I get around this
-thanks
the answer is simple.
your file isn't vcd. vcds are 25, 29,97 or 23,976 fps. so nero doesn't know what to do with it.
what you need to do is reencode your file but i don't know what you can do to get a good result out of a 14.98 per second. -
VCDs are either 25fps or 29.97 fps NOT 23.976 fps. As for going from 14.98 to whatever, just load your source file into TMPGEnc, pick your VCD template and go. Don't check the "Do not framerate conversion box".
Convert AVI and burn to DVD: problem w/ NERO
By jimbo213 in forum Video ConversionReplies: 3Last Post: 3rd Aug 2009, 05:10 -
problem with my cd/dvd-rw drive or with nero or both!
By NBABE1 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2008, 14:20 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40 -
Camcorder to DVD Problem using NERO
By rhodellf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 3rd Oct 2007, 19:51 -
Problem finalising DVD+R media with Nero - pls help
By Darren_NZ in forum Authoring (DVD)Replies: 6Last Post: 19th Jul 2007, 15:16
