  1. Anonymous
    Guest
    How is it that I can deselect BOTH choices of "Decode with" and it still works??
    Which is operating, if neither is selected?
    In what instance is it required to use QuickTime? (ever?)
  2. If you deselect both, mpeg2dec or ffmpeg are used to decode. Using quicktime solves sound sync when it is an issue with the other decoders.
  3. Anonymous
    Guest
    Ok...
    But what if it's a DiVX .avi file?
    It still seems to process them, does mpeg2dec or ffmpeg work with these?
    Thanks.
  4. Default decoder for .avi is ffmpeg.
