Has Anybody found dvd-r media that works with the dru-510a burner.
I`ve tried datawrite red [80% failure] and verbatim 2x [50% failure].
I`m using the latest firmware but i keep getting the same write errors.
This is getting expensive!
Results 1 to 11 of 11
I haven't burned a *lot* of disks (not enough to give a % failure/success rate), but I have had no problems with Memorex 1x and Princo 1x (identified by Compusa as FMI).
I've used lots of -R's in this drive. CompUSA, Sony, TDK, and a sample pack I got from Rima including Princo, Optodisc, Ritek. Right now I'm going througha 50 pack of DupEz 4x printables I got from Rima. No problems at all...
Have had no problems so far with Verbatim Datalife 2x, Imation, Pioneer 4x. Also no problems with +R and +/-RW media from Imation.
In addition to the above-mentioned 1X Princos and 1X Memorex (CMC), both DVD-R, I have since burned DVD-Rs by Ritek 4X, Memorex (CMC) 4X, and TDK 2X. I have also burned Maxell DVD+R 2.4X and Memorex DVD+R and Memorex DVD+RW.
All burned successfully. -
Best buy had an awesome sale on TDK 4x DVD+4. I've burned at least 20 dvd's already at 4x, and I haven't gotten a single problem yet.
I use Accus, work perfect. 1x Accus read @ 2x on the Sony with the right firmware (e or better)
btw, meritline.com can tell you what to use on your machine. Accus are like under $1 each
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 06:07 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
media : blu-ray media range and more
By angel40204 in forum MediaReplies: 0Last Post: 8th Oct 2009, 07:14 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58
