I´m running windows Me and instal New ASPI into my PC (the file name is "aspi_471a2.exe" ), because i´ve been having some problems with my Dvd-recorder (toshiba sd-r5002), and i installed the aspi v.4.60 and iwhen i run the "aspichk" it tell me that it´s all fine and great !!!
But i notice that there's avaiable the version 4.712, and i download it, and installed it.But when i run the "aspichk" it say that "ASPI is not properly installed." and display's this info:
version size
wnaspi32.dll 4.712 45056 bytes
winaspi.dll 4.60 5600 bytes
apix.vxd 4.712 23115 bytes
aspienum.vxd 4.60 7743 bytes
the ASPIchk.txt:
LOG0143: ************************************************** ***************
LOG0144: Starting ASPICHK installer on Mon Jul 21 11:15:32 2003
ASPICHK0438: OS = Windows 95 (4.90.3000)
UPGRADE1004: c:\windows\system\wnaspi32.dll dated 07/17/2002 15:03:58, 45056 bytes.
UPGRADE1062: c:\windows\system\wnaspi32.dll version 4.71.2.0
UPGRADE1004: c:\windows\system\winaspi.dll dated 09/10/1999 11:06:00, 5600 bytes.
UPGRADE1062: c:\windows\system\winaspi.dll version 4.6.0.1021
UPGRADE1004: c:\windows\system\iosubsys\apix.vxd dated 07/17/2002 14:54:02, 23115 bytes.
UPGRADE1062: c:\windows\system\iosubsys\apix.vxd version 4.71.2.0
UPGRADE1004: c:\windows\system\aspienum.vxd dated 09/10/1999 11:06:00, 7743 bytes.
UPGRADE1062: c:\windows\system\aspienum.vxd version 4.6.0.1021
ASPICHK0522: Inconsistent version numbers among components
ASPICHK0592: ASPI installation has problems
LOG0218: Closing installer log on Mon Jul 21 11:15:32 2003
LOG0219: ************************************************** ***************
But if i run the "new aspichk" (the one that cames with the new aspi driver) it doesn´t say that the drivers aren't properly installed and shows this:
version size
wnaspi32.dll 4.712 23115 bytes
apix.vxd 4.712 45056 bytes
and:
ASPI is properly installed and is fully operational
What do you think, should i keep the newer version or go it the 4.60 ?!?
Results 1 to 1 of 1
ASPI for XP x64
By HartsVideo in forum Video ConversionReplies: 12Last Post: 6th Jul 2008, 04:20
