After capturing and everything else done [create, edit, encoded, create Video/Audio TS, and image] test it works on most players but problem is when buring the DVDR from the image using DVD Decrypter [from suggestions from members here that it will be most compatible with most player] 3.160 or something [newest] but 1/2 way through of 90% sometimes it hangs.... why is that so. This happens sometimes [about 30-60%] and other times it is ok ? I am using Windows 2000 w/SP=2. The drive is a Firewire 1394 drive. I had no issues when using nero [newest one] to create DATA disk but when buring an image or ISO file it hangs sometimes but not all the time. What can I do to eliminate this ? As it cause quite a bit of cost for us. I am using DVD Decrypter 3.160 or nero 5.10 and win2k and ImgTool [newest]. They are wedding library made from Betacam SP.
Milk, yoghurts, cream and other such dairy products and hardware don't mix - keep them seperate at all times !
Sorry, couldn't resist. Slow day at work. You know how it is.
Seriously, since it doesn't hang at the same point every time I'm wondering if it's hardware related. I have seen similar problems caused by faulty / insufficient power supplies, iffy connectors, faulty IDE cables and memory that's on the edge.
Does the problem only show up when recording ? Did the problem arrive with the writer ? If so, think cables and / or power supply.
Try using the image with another application - I think all the authoring programs out there should be able to burn an ISO image.
looking for the softwares for for general movie / wedding video making
By bengaltiger in forum EditingReplies: 2Last Post: 19th Apr 2009, 14:27 -
DVD with a home made video of a wedding can not get it work on dvd player
By kyrieanddave in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 11:03 -
Editing unedited Wedding DVD + frame edits?
By OldCanon in forum EditingReplies: 2Last Post: 8th Mar 2008, 12:41 -
Wedding video camcorder dvd-rw accidentally shot over.
By jim s in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2007, 10:03 -
Buying Music for Wedding DVD's
By pcbrown in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2007, 09:55
