when im making VCD's from variouse DivX fles, my final VCD seems to slow down and speed up, every now again?
anyone know whats going on?
Results 1 to 11 of 11
i think ive figured it out m8!
i have lots of settings in my DVD menue, i didnt have the auido to bitrate, it was set to something else, i remeber changing it, so i put it back to bitrate and now its fine! -
Well them settings sorted some of it out, but its still out of sync in some places
its fine on my PC -
can someone plz help, the VCD's are ok on my pc its just on my dvd player!
i got a encore DVD player -
My only thought is that the VCD you are creating is not 100% VCD compliant.
Is it? -
if it wasnt 100% VCD complaint then 1. nero wouldnt let me burn it and 2. it woulnt play on my dvd player
Why dont you be more specific in your posts, like give all the information that may be relavent in the beginning. What do you use to encode etc? If the VCD is 100% compliant then it would play OK wouldnt it - Unless your player is messed up or the player doesnt like the media that you use.
Does the audio speed up and slow down or the video? Or both?
<font size=-1>[ This Message was edited by: d4n13l on 2001-09-30 14:36:09 ]</font> -
Hi i also have a Dxr3 encore. I got the same problems. When I convert a avi to mpg, and play it on my encore DVD the picture hack, and the audio gets out of sync. when i play the movie in my mediaplayer it works perfect...I red in this forum about drivers from Real Magic Hollywood+.To use with the encore.With this driver it would be possible to play Avi's too.?? Have downloded the drivers, but not installed them....(Big Krasch..*smile* )If you search for Encore you find these replys yourself..
Excuse for my bad english....(smile)
Chris
ok im i think its tmpg, im trying the panasonic mpeg1 programme now, but its taking ages man!
whats this avi on my DVD player
KAV slowing down internet?
By Tbag in forum ComputerReplies: 0Last Post: 7th Jan 2009, 13:36 -
vcd audio slowing
By samdbl in forum Authoring (VCD/SVCD)Replies: 2Last Post: 11th Dec 2008, 22:11 -
How do you know if its ram or processor slowing a game?
By yoda313 in forum Off topicReplies: 6Last Post: 2nd Sep 2007, 08:55 -
slowing down a movie
By natty in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2007, 06:51 -
ConvertXtoDvd slowing down ca. half way.
By BlackRose in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2007, 08:22
