My files are large I would like to compress so that it can fit into 1 cdr. Which compression program has the highest ratio Please indicate the ratio. Zip, rar,lha,tar etc...Anyone? Thanks
Rar compress a bit better than zip. But you wont be able to compress video that much, the best way to compress video is to reencode to another compressed format(lose some video quality).
is this just for transporting purposes or do you also want to play the video directly off of the CD-R?
It's for archive purpose Anyway I found out the best would be 7-zip.Much higher than rar winzip etc...Thanks anyway.
Best compression, smallest size, highest quality?
By Sullah in forum Video ConversionReplies: 17Last Post: 12th Nov 2022, 10:48 -
Highest bitrate for AC-3 2.0?
By Anonymous344 in forum AudioReplies: 8Last Post: 15th Mar 2010, 17:29 -
Highest quality backups
By freewave in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2010, 19:32 -
Compressing with the highest quality
By guitarscn in forum Newbie / General discussionsReplies: 6Last Post: 26th Apr 2008, 14:02 -
Highest Compression Codec?
By Solonor in forum Newbie / General discussionsReplies: 7Last Post: 27th Dec 2007, 17:40
