Hi all,
I have authored many DVD's using Maestro now and am stumped on how to do something. I have converted several 8mm tapes to DVD and now I want to add 3 different sound tracks. The reason being that whom ever watches these old moves will be able to select their desired music (i.e. brother heavy metal, parent classical ..etc).
So I was thinking I would add 3 audio tracks... easy enough, the problem being how can I get 3 seperate buttons on the title to play the appropriate music file when the movie starts. I figure when u play a DVD you go into a setup screen and can selet a seperate audio track (english french ...etc). So this should be a farily common task yet I can't seem to figure it out. Any suggestions would be greatly appreciated. Thanks!
rhuala
In short, here's what to do.
Add in your multiple soundtracks and note what track number each one is.
In your meny, create a button. Select it and go to the "buttons" tab. You can the assign an action for the button to change various things like subtitle and audio streams. Select 'audio' and the number of the stream that you want that buttone to select.
That's it."Weekends don't count unless you spend them doing something completely pointless."
Bartman 8) -
hey thanks Bartman,
I was trying a way using command sequences and needed to compile it to see if it worked. I read your post before compiling so I'll give your suggestion a try. Thanks again.
BJ_M, why waste time posting a stupid suggestion, are you really that bored?
rhuala -
Originally Posted by rhuala2
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
Back up 1 title track split across 2 DL DVDs
By soneman in forum DVD RippingReplies: 11Last Post: 24th Mar 2010, 05:50 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
selecting audio track
By july in forum AudioReplies: 0Last Post: 9th Jan 2009, 15:13 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 08:25
