heres my process : .bin files, put them through svcdtodvdmpg changing 1st header so to make them compliant with uleadmf2,once they have been through uleadmf2 i put them back through svcdtodvdmpg changing the entire file and set @ 480. I then burn the VIDEO_TS folder in nero using udf mode. I seem to be having problems with the finalised disc as they play only on some dvd standalones, if you have a better way of doing this i would greatly appreciate some advice![]()
Or try with Recordnow max or Copytodvd. Demo available for both tools.
www.dvdrhelp.com/tools -
thx guys. the process i have mentioned above has had very undesirable affects, i was toying with the dvd, i opened up dvd shrink and it wouldnt even open up the dvd at all, which is unusual as it opens up every other dvd i have, but doesnt with these svcd transfered files.
can not record in +vr mode
By bad channel in forum Capturing and VCRReplies: 9Last Post: 11th Jul 2017, 18:00 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 09:28 -
Cannot record in +VR mode
By hornsfan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Dec 2009, 22:40 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 16:27
