Like this one:
http://f1.pg.briefcase.yahoo.com/bc/steve_bg_2000/vwp2?.tok=bcEuc6RByCqAVTa0&.dir=/mpe...hz.mpg&.src=bc
I have made it by a complicated procedure, by saving separate frames than renaming manually, each frame in order to make the last first and vice-versa...
The question is -- do you know a program which can reverse a videclip the same way as Windows Sound Recorder can reverse an audioclip to play backwards ?
thank you.
Best wishes,
UP -
Link did not work for me
Try this in either Virtual Dub or your own NLE . It must accept avisynth framserving though !
http://www.avisynth.org/index.php?page=Reverse
Ulead Media Studio Pro can do it for you with one click. But it's not freeware or shareware. It's a full editing program.
Use Adobe Premiere...
Set speed of clip to -100%... it wil play backwards!!!
'HAG -
Vegas Video can also reverse clips easily.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Guys,
thanks for the advice.
The link definetely works, I tryed, however it was pathetically slow.Best wishes,
UP
Madonna's Halftime-What video effect to make entire show look different?
By jimcornetet in forum Newbie / General discussionsReplies: 0Last Post: 6th Feb 2012, 12:40 -
Sony Vegas how to make this effect?
By wingfan in forum EditingReplies: 0Last Post: 16th Jun 2011, 11:53 -
Urgent: how to make a photo effect zooming in and out in slow motion
By bototucuxi in forum EditingReplies: 5Last Post: 4th Jun 2011, 00:46 -
ping to introduce traffic
By ahidayat in forum ComputerReplies: 8Last Post: 26th Mar 2009, 09:08 -
Software suggestion to make special effect of voice
By bambam in forum AudioReplies: 4Last Post: 17th Mar 2008, 10:40
