Hello,
I was wondering if this is a bad sign or nothing to worry about. I'm using iuVCR to capture to avi with PicVideo in a resolution of 480x480. I notice on their graph that during the whole capture the usage of the cpu is at of near the top of the chart. However, there are no dropped frames at all.
Also, I have in the settings to capture at 29.97fps, but when I start the capture, it gradually builds up to 29.97 after about 2 mins or so then stays at about that for the rest of the capture. Is this normal or is there a problem somewhere? The resulting capture looks fine when I watch it/encode it with TMPGEnc.
Here are my specs:
Pentium 3 500 mhz
512 MB Ram
8 MB AGP video
ATA/100 WD 40GB HD 7200rpm
I have all the background apps turned off including antivirus, etc.
Thanks for any insight
That's kind of high actually, but if depends on the codec/filters you are running. I know several people that used 350Mhz machines to capture at 720x480 (uncompressed) and had no problems. But try to capture to MPEG2...
Anyway, if you're not dropping frames it doesn't really matter.
What do i need if CPU usage goes 100% when video editing?
By NaHLiJ in forum Newbie / General discussionsReplies: 19Last Post: 28th Dec 2013, 20:13 -
MPEG Streamclip issues - 100% CPU usage, unusable...
By semmel in forum Video ConversionReplies: 6Last Post: 27th Dec 2009, 18:27 -
HD playback suddenly broken - 100% cpu usage
By mr-scarface in forum Software PlayingReplies: 11Last Post: 16th Apr 2009, 16:12 -
CPU usage goes to 100%
By Tbag in forum ComputerReplies: 21Last Post: 18th Jan 2008, 10:59 -
Jumpy playback, dropped frames during capture, CPU pegged to 100%
By tylerz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2007, 18:09
