Anyone know if there are plans for a Panasonic DVD recorder with a firewire input? Sony has the firewire input but no hard drive, Panasonic has the hard drive but no firewire.....
Panasonic DMR-HS2 has always had firewire input. It came out last October:
http://reviews.cnet.com/4505-6505_7-20100468.html?tag=txt -
I believe the E60 has a Firewire as well. However, this model, like the E50, does not have hard drive.
I have the E60 - it has FireWire. No hard drive.
I have dubbed about 10 videos via FireWire. Look very good. Only problem is that is is supposed to insert chapter breaks every five minutes and some of the videos have breaks every 2-3 minutes which is annoying. Very ugly menus. Allows you to set disk titles, but I havent seen where you can set program titles yet (haven't really looked).
E -
Pioneers new model coming out his Fall which is a dvd-r/dvd-rw will have a bi-directional firewire input/output. The panasonic's E100H is only an input.
Originally Posted by EricS
I have the E-30. Assuming that it's the same to set program titles, press return, then highlight the program and hit the (right) --> to get the options. You can then spell out the title you want like the disk titler. Note that you can erase all of the date/channel info already there to give you more room.
Panasonic PV-HD1000 firewire out?
By Des in forum Capturing and VCRReplies: 5Last Post: 14th Oct 2011, 14:01 -
Panasonic DV Firewire problem
By darrenkarp in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2010, 13:28 -
Connecting Panasonic DVD Recorders with DV input to PC
By PeBo in forum DVD & Blu-ray RecordersReplies: 30Last Post: 26th Apr 2010, 05:51 -
Panasonic TH-42PWD8UK Dual input wont go away!
By abocken in forum Newbie / General discussionsReplies: 0Last Post: 8th Apr 2008, 07:48 -
Sony HDR-FX1 firewire-input-port
By stompinne in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 25th Feb 2008, 14:23
