  1. Member Gritz's Avatar
    Feb 2003
    Just recorded a 75 picture slide show with music using MyDVD and the audio has a constant background click after recording. Using XP Pro, MyDVD 4.0.2 and the audio to go with the slide show is a long MP3. I have the XP Live Driver Pack and Patch, and the sound is ok before writting to DVD-R. Would converting the MP3 to Wav make it better, or worse? Any help appreciated.
    "No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
  2. Member Gritz's Avatar
    Feb 2003
    Ok .... found a fix. Seems MyDVD has a problem with MP3s (and I tried it on 2 different system and got the same results ...audio clicking). I converted the MP3s to aiff and it worked fine. Must have something to do with MP3 being compressed and aiff not? Although the program (MyDVD) talks about using MP3s throughout ...... their support team doesn't answer my email so I guess they don't know.
