I am using clad dvd, to rip, and then dvd2avi to frameserve into tmpgenc, when i get all done encoding into mpeg 1 video cd format The audio is about 10 seconds out of sync with the video. I am even trying to copy superman the movie, just like in Sefy's guide. Please help I have tried looking in the forums, no one seems to know much about this particalur, large async problem.
A common problem is forgetting to load a Template, have you loaded one ? have you followed the steps correctly ? just for the testing, have you tried playing back the VCD on another PC ? sometimes the sync is caused by the Decoder itself.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Yes I loaded the template, totally vcd compliant, i burned it onto a cd using nero, same problem audio on my dvd player, philips 825, way out of sync. I found another post that said they fixed the problem by using dvd2avi save a project of part of the movie, but i can't figure out how to do it...if you can.
Hi themattman,
I had a similar problem recently and found this link on a helful reply in the forum somewhere.
http://www.digital-digest.com/nickyguides/audio-synch.htm
The key was frameserving with VirtualDub which is a great bit of software.
It helped me and I hope it can help you also.
Best wishes,
Barry Webber.
bazwaldo@ntlworld.com
#:-) Trying hard to switch to Linux (-:#
HUGE Ripping Problem...HELP
By mgbatman in forum DVD RippingReplies: 9Last Post: 27th Nov 2010, 01:41 -
I hate this out-of-sync problem from my ripping.... UGH!!!!!
By Heyjoojoo in forum DVD RippingReplies: 16Last Post: 10th Apr 2010, 11:56 -
Off sync audio problems - is it ripping or encoding?
By kirklt in forum DVD RippingReplies: 3Last Post: 14th Jul 2009, 10:48 -
audio sync problems after ripping dvd
By blubot in forum Video ConversionReplies: 4Last Post: 23rd Sep 2008, 10:14 -
Sefy's Guide and Correct Setting for DVD (NTSC).mcf
By moviebuff2 in forum Newbie / General discussionsReplies: 8Last Post: 1st Aug 2007, 09:01
