As all of you who use Sonic's DVDit know, you can insert very nice pre-made buttons which act as single floating objects that can then be linked to movie clicks or sub menus. My question is, how can I make my own custom buttons in say, Photoshop 7. I've been having problems in that even if I create a button as a layer over a transparent background I can't get it to work in DVDit. If I save it as a PSD with layers intact, and then import the psd into the DVDit buttons pallete, only the backgound is imported. If I flatten it and save it as a JPG or whatever, the previously trasparent background becomes opaque I want to be able to create objects that are simply that. Not a circular button encased in a square document. I hope I am making sense here. Anyone have any ideas? I am not lacking in most Graphic programs so any suggestions would be appreciated immensely.
No DVD can withstand the power of DVDShrink along with AnyDVD!
Is there no one out there that can possibly provide me with some info on this Please!!!!!!
No DVD can withstand the power of DVDShrink along with AnyDVD! -
In Photoshop, instead of "flattening" the image, I think you need to click on the "merge visible" action so that you end up with one layer that has the button on a transparent canvas. Then save as PSD and input to DVDit!
Good luck -
Thanks!!!!
Proplem with mapping menu and title buttons using DVDit PRO 6
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 14th Apr 2010, 17:56 -
DVD-Lab Pro 2, making shaped buttons from parts of menu background?
By bizzybody in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2008, 20:06 -
Re: index buttons when making a DVD
By tomcat862 in forum Authoring (DVD)Replies: 1Last Post: 22nd Feb 2008, 05:24 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Animated Buttons
By Paulodemoc in forum Authoring (DVD)Replies: 3Last Post: 27th May 2007, 16:39
