This is my problem, My mate Decrypted His DVD onto my computer and I've got the VOB files.
Is there a way I can Burn them to DVDR without Converting it to MPEG2
I'm assuming that they are the VOB's only and they don't have their accompanying IFO and BUp files?
If so, you can use an authoring program that accepts VOBs as input, then have it build the files you need and burn the resulting compilation.
If all the necessary files are there, you should just be able to dump the files into an VIDEO_TS folder, make an empty AUDIO_TS folder and burn.
Hope this is what you were looking for. -
they are VOB's only and they don't have, IFO and BUp files.
But What are/is the best authoring program that accepts VOBs -
Use IFOEdit to create the IFO files then grab a trial copy of TMPGenc Author and use the "Import DVD Files" button instead of the "Import Files". You will be able to create a DVD with menus and chapters.
"Only Users Lose Drugs" -
IfoEdit is free, and can create the bup and ifo files from your vobs. I'm not positive, but I believe that you just need to open the first vob file in the sequence, and then click on the create ifos button. I'm at work, and so I don't have the program with me, so if that's not correct, look around for a guide either on this website, or doom9.net.
To Be honest this all sounds omplicated, I'd prefer if some1 could please send me VOB Instant CD/DVD. And I can follow to guide.
My email is:
rhemel@ntlworld.com
www.vob.de isn't working.
Thank U!
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
How to burn multiple VIDEO_TS folders to one DVDR w/Menus/Chapters
By Iceman67 in forum MacReplies: 11Last Post: 23rd Jan 2010, 17:10 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
edit Vob files in DVDR movies?
By SUPERIOR in forum Newbie / General discussionsReplies: 6Last Post: 12th Feb 2008, 11:12 -
Cant burn on -dvdr disc
By dnst3 in forum Newbie / General discussionsReplies: 11Last Post: 20th Dec 2007, 01:46
