I was reading up on dual layer DVD-9 in the sticky thread, but I was wondering if anybody can suggest some good software/methods to split DVD-9s onto two disks using a Mac. I use DVD2One and Toast, of course, to burn DVDs, but I have no idea how to split and burn dual layers. Or, is there even a way to reduce the files to fit on one DVD-5, sacrificing a little quality?
I apologize if this has been asked recently. I did a forum search but didn't see too many Mac-based threads, so hopefully it hasn't been
Thank you very much for helpin' me out.
FOA, if you use DVD2One like you claim to be then you would know that its sole purpose is to squeeze DVD-9 discs into a DVD-5. This is one way of solving your problem.
If you want to span the movie onto two discs to preserve the quality, then ignore other threads in this forum and use DiscomVOBulator, which can be found here: http://www.kaisakura.com
Both programs are shareware. -
Originally Posted by darkjustice2099
2. Discomvobulator - splits a dvd 9 over two dvd5 keeping origional structure (but 1/2 of the movie is on the 1st and 2/2 of the movie is on the 2nd disk) so you have to switch disks half way though.
OR
you could by a dual sided DVDr (4.4 on one side, 4.4 on other side) burn to both sides of the disk (part 1 on top, part 2 on bottom) and just flip the disk when you get to the 1/2 mark. THis keeps it on 1 disk, but they are more $$.
Basic DVD Burning for Mac
By The Monkees in forum MacReplies: 8Last Post: 9th Mar 2010, 17:30 -
DVD-Audio disc burning on Mac?
By karipu in forum MacReplies: 12Last Post: 25th Apr 2009, 18:48 -
Burning DVD with subtitles on a mac
By villa99 in forum Authoring (DVD)Replies: 1Last Post: 1st Dec 2008, 13:23 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24 -
Problem burning DVD+DL disks
By ejai in forum MediaReplies: 16Last Post: 27th Jun 2007, 09:46
