  1. Hi, I have a Mpeg which has a resolution of 512x322 (I think) and i would like to resize it to 352x240. how can I do this without having to re-encode through Tmpgenc. Or whatever there is I don't know???
    Thank you to all in advance.
  2. you cant resize if you dont encode the file again.
    you can try and burn it but this will create an xsvcd / xvcd
    depends on the mpeg format.
    it might not play on your dvd player.
    HELL AINT A BAD PLACE TO BE
